Timing light with Tach. Can I use it?
adaptor tips, which way?
Need a transmission line
Hey guys. I posted a while ago about the high idle on my truck. Now that I know how to bring the idle down, I need to know where to set it. I don't have a tach(I know... Bad Andy!) but my timing light has a built in tach. Do you suppose I could use it to set the idle speed on my truck? Obviously I can't use it like a gas engine. If I can use it, can some one tell me were it needs to be hooked to the alternator?
If I'm way out of line, let me know.
Andrew
A timing light that works off of an ignition system won't work, I have heard they make some that are trigered by the pulses in the injector lines but I've not seen one.
Caleb
certain timing lights had a magnetic pickup sensor that plugged in a socket by the damper pulley. there was a magnet imbedded in the damper. if you have one of those, you might be able to temporarily tape a small magnet to the damper and try to hold the sensor rod near it. ????
the only other thing i can think of is to use an optical tachometer that reflects off a marker tape on the crank damper. these things arent cheap. they run around $200. w. w. grainger has them and other places too.
jim
There is another option... .
I think it is/may be a snap-on tool.
It uses a small clamp with a piezoelectric sensor. This gets clamped around the #1 fuel line. The output is fed to a timing light and it functions exactly like a normal gas engine timing light.
You need to establish TDC and you need to make a marker needle from wire. This is usually attached to the pan bolts at the front of the pan, with the wire pointer extending over the harmonic dampner.
PB...
