I am looking for comments from those of you that use a timing light to set/check timing. I had mine set to 17 degrees almost 5 years ago. This was in conjuction with replacing the HG which added lower compression into the mix (milled . 008 replaced with . 020). Ever since, when temps are cool I have had hazing (still factory 215 injectors) and smoke that really burns your eyes. I have always written this off do to the lower compression. This winter cold starting (below -5F) is getting tough. Engine starts but idles very rough and you can not give it any throttle or it stumbles ("floods") and everything around you disappears in white smoke. When truck or ambient temps are 30 or above, starting running are like a champ... other then a little hazing.
While I would like to think I am at 17 degrees I am starting to think not. From what I know and read, the above symptoms are classic low timing. I am going to have the timing checked again. Did this a year ago and it was still dead on 17... using the same mark on the dampener used from the beginning. This time we are gong to verify (and verify again) TDC is dead on. My questions is when checking timing off the #1 injector line there is difference in the reading depending on where you get the signal. Do you get a more accurate reading when the signal is nearest the injector on the line or nearest to pump? Is checking/setting timing with this method as good as spill port or others?
I have a new overflow valve coming and plan on replacing the injectors very soon.
Thanks for any help... .
JJW
ND
JJW
ND
