I would love your opinion regarding the timing of the pump in combination with water/meth and a tiny amount of propane( just for economic and clean burn reasons, propane costs less than half of the dieselfuel in Europe)
So far I run stock timing and the other modifications are:
95 stc 2wd,TST# 4, 16cm non wastegated housing, 3kgsk, 4 inch exhaust, k&n filter,192 dv, 370 marine injectors, trans go shift kit, edgeracing workhorse billet conv. , gear vendor overdrive,3. 54gears,22" 305/45 22's, (we have the autobahn and it´s fun to beat the V10 Tuaregs in top speed)egt,boost,trans temp,stageII snow perf. water/meth,bullydog propane inj.
I should repeat that I'll go very conservative on propane and plan to ad water meth(50:50) starting with 23psi of boost. without drugs I see 42 psi at the moment. Since propane and water meth both advance the timing I'm not sure if I should leave it stock or slightly advance it. Please tell me your opinion.
Thomas Tork (Germany)
