Timken bearing part number
2019 RAM 3500 WHEEL SWAP TO 2004 RAM 3500
Front outer ujoints
RPosey
A little help please. Any one out know the
Timken part number for gen 3, year 03, 4 wheel drive front wheel bearing without hub?
If you’re trying to save money, you won’t save much, IF you can find it. I priced some yesterday for a fellow at work. He had a Tundra. The bearing was $160 and the hub was $190. $30 wouldn’t cover my time to press it out and a new one in, not to mention the probability of tearing the bearing up. They’re basically two roller bearings with one outer race. The center race is split and VERY easy to mess up.
I agree with that. I assumed the bearing only would be closer to
$30
Pushed the wrong button
Tried to pay with card , they said just wait till you get invoice. I almost flipped out when he said that. Who sends a part then ask for money later. 610-593-2753
The rest of the story. I found a place in Penn that sell bearings really reasonable for the best to satisfactory quality. Example needed bearing , no hub for hay roller. International farm supply about $400, $90 from tributor if you knew someone. Pennsylvania co. $22, I thought wow. Did not want money till parts arrived with invoice. Who does that 610-593-2753
Did you find the hearing only that you were looking for?
Did not find part #
Did not find part #, still looking. I have seen a post that say they installed bearing only, two comments, one said took more than 20 ton press, other one said he did it with 15 ton press. Maybe you can help.
