Darkbloodmon
Looking for the Timken P/N for the clutch release bearing on my 03 5.9 NV5600, I've seen some conflicting numbers online and searched the archives and this forum already.
Additionally I'm getting ready to swap my clutch amongst many other parts and pieces come spring break if I have enough sober hands that aren't flying out of town, if not then than early summer. I've been wondering if anyone has any experience with Phoenix Friction Clutch components? I see a lot about south bend and Vlair amongst other big names etc. But im more of a question first observe second unless my gut tells me it's a sure bet. Any advice on the process of getting this war head out from underneath my barge would be appreciated(I know what parts im going to replace rear main, oil pan gask, Fleece coolant bypass, came seal, etc.), I will be doing this in my driveway most likely with the T case attached, I've been told you could sling it with ratchet straps on the frame. I do have a trans jack.
The Truck: is an 03 HO 5.9 NV5600 207K when I got it after the previous 4 family owners who had been towing in Alaska with a fifth wheel as the crude bed holes are still there. I daily it to College and work 20mi a day if that. I've previously installed a new stock shifter from allstate gear and dual Fast trans coolers from Genos, she's sloshing 7 quarts of the finest.
My setup will be a Phoenix Friction Stage 3 HD Kevlar Clutch 13" said to be good for many many miles of smooth engagement and moderate towing rated for 490HP and 880lbft (provided the 1K mi break in) ,I'm not sure about their pressure plate I might take some time to research a better one if my doubts grow, I'm not using their pilot or clutch release bearing as per this thread title. I will be using a South bend HD roller bearing flywheel. A new fork and stainless pivot stud from Allstate Gear and a new Hydro assembly though the current one is still fine.
Once I get everything in i'll post a review of my install process and after thoughts especially on the clutch feel and operation.
Here is a link to the clutch: https://www.phoenixfriction.com/p-2...iesel-ram-2500-3500-6-speed-nv5600-13-in.aspx
I like the options they have, they seem to know their stuff. Time will tell since I've not seen many reviews on their products, maybe they're a hidden gem.
