OK All. !!. Built it. . not as fancy as that one rich but it works.
I made 5 circuits. . left turn, right turn, lights, back up, and Electric Brakes
First the parts list.
This is a Cannex 5x5x2" Box. It has a seal on the lid.
http://www.westernextralite.com/inde...=can 5133706 ... $18
3 Rolls of 10 Gauge primary wire. .
a 40 amp Circuit Breaker. Yellow tab is the reset. $39
http://www.wiringproducts.com/conten..._breakers.html
25 feet of Split wire loom 3/8" $13
a prewired relay socket. . 5 of these. . Red wire is switch for relay. White is ground, Black is power direct from Battery, and Green is Load out to lights. $4. 28 Ea.
http://www.wiringproducts.com/contents/en-us/p565.html
a 50 amp relay. . I bought a 5 pin but should have done a 4. . All I did was clip the center blue wire short and use it as a 4 pin relay. . Buy 5 Relays $7. 49 ea.
http://www.wiringproducts.com/contents/en-us/p65.html
This is the "T" connector for our truck. I have a 09 and you search for yours... the 4 wire is not on the protected side so you have to clip and modify this. $14
http://www.autopartsasap.com/2009-Do...ly-118381.html
Ok, this next image is looking at the end of the harness with the red clip on top. for what wire is what.
OK, now, here are the 5 relays connected to the 5 wire sockets. . Red wires are signal wires, white is ground, black is bat. + and green is the load output... I made 2 1/2" holes in the side of the box. . signal, ground and load out one side, power out the other.
The wires are all soldered and wrapped. . that Scotchlock is a forgotten ground wire. Top side of image is from the harness, tap into the ground, from the 5 white wire. Clip wires one at a time to the relays. . red wire to upper inbound, green wire to lower outbound, as well as the 4 wire plug. . Notice the clipped 4 wire on the top part.
Loose layout . . Black power wires not hooked up yet. .
Finished and wrapped. . I used weatherstrip adhesive to seal off the side holes. So just connect the harness to the truck and string the power wire to the front battery area.
The side of the power Module has the connection for the battery. Connected it to the Circuit Breaker.
OK, added the Circuit breaker to the box and incredibly it fits inside. . the Type 2 ATC Circuit breaker stays open til the overload condition is removed. . the 5 circuits are lights, LT, RT Elec. brake, and backup.
Ok, Thats it on this. . I made this and wired it up as I showed you and it works. . Funny thing is I hear from outside, I hear the relay clicking in the box. . but oh well... With the longer 4 wire plug, I was able to route it to just beside the 7 blade plug. I used a skinny Zip tie to hold it in position. .
DISCLAIMER: This is my own making and although it works I assume no responsibility if others have mishaps. you are free to copy and buy and make this system yourself.
