2nd Gen Non-Engine/Transmission Tire Change
Engine/Transmission (1994 - 1998) quick boost vs EGT ?
my dually rides like a rock when I'm not towing my 5th wheel.
Running Goodyear 235/08/R16 E Range. Cant lower the pressure enough(below 35psi) to make it ride better.
Is ther a tire this size in a D Range that mught give me a softer ride?
40psi at load is more than enough to handle the hitchweight of the trailer.
You may want to try Rancho adjustable shocks. I set them on the softest setting when empty and it rides great even if I leave 75lbs in rear tires. . Just a thought... ...
