Tire hieght on the new Rams.
New Member Questions
Recalls n do they apply to used Rams.
I see my the sigs, that a lot of you have changed the wheels/tires on your newer Rams.
I have a new 2001 3500 on order and my dealer says you can't change the tire size/hieght due to the on board computer/rpm/mph/trip etc.
How are you changing tire sizes?
Thanks
Lost and confused
Bob
1998. 5, 2500, SLT, 24V, 4X4, Auto, 4. 10 towing 35ft. 5er
On Order due May 1. 3500, SLT+, Green/Tan, HO, 6 speed, 4X4, 4. 10, towing package, camper package, E-brakes.
On my 98. 5 I installed 285, stock back then was 245.
Looks a lot better witht the bigger sneakers.
I went with 285 mudders also, but I found out the hard way that I was traveling 5 mph faster than what I was indicating. (highway p-troll)
M. Foshee Jr.
2001-Dodge 2500 4x4
My 2001 had the 265's stock, but I quickly changed to 285's. The tire shop said to figure about 5mph. . as was mentioned in the previous post. I haven't changed any chips or anything... not sure if they're available. I'll be interested to see what a others have to say.
jjdiesel,
What is the address of the JRE website?
is the calibrator for the antilock speed sensor for the spedometer? is there a way to change the size of the tire on the sensor with the calibrator?
2001 QC 2500 4x4 bronze W/two tone Driftwood, 24valve HO 6sp. Westin side bars, fender flares, Rancho RSX off-road shocks, Spray on bedliner, Leer shell Painted to match with LED marker lights, Bf Goodrich AT Tires. Bed rug inside shell W/aux marine deep cycle batt for lights, etc. M Brolins' CB mount.
Name of rig is "big bronze Brute"
Go to Abbott-tach.com and click on products. It's called a ERA, electronic ratio adapter. It will work for virtually any size tire. JRE is Jannettyracing.com
I JUST PICKED UP A DIFFERENT SPEEDO GEAR FROM THE DEALER, THE AUTO SHIFTS VIA THE SPEED SENSER(SPEEDO). TOOK ABOUT 20-30 MINS. COST ABOUT $10-$12 BUCKS!
JRG
