So we don't confuse load range with load rating, the load range identifies the strength of the sidewall. Load rating is an indication of how much weight the tire will carry. The reason the D range tires are only rated for 65 psi is the strength of the sidewall. E series are stiffer and will typically carry a higher psi when towing heavy. The unacceptable flex I'm talking about is the type you get when towing heavy with a lower air pressure. When a truck passes you and you start to wiggle a little, some of that is caused by tire flex. Or when you turn sharp and the tire tends to flex and roll. If the tires have a stiffer sidewall and are "aired up" then there will be less of that. Also, tire manufacturers recommend that you never go down in a sidewall rating from what comes as OEM equipment. If you are following the guidelines on the D tires and have adequate air pressure to maintain a required load rating, you probably won't get any unacceptable flex. When I sold my 01 Ram, the OEM Michelins had 118,000 miles on them. About 40%/60% towing/empty. They were Range E.
