From what I've read dually and single rear wheel trucks respectively have the same front axle weight ratings. So 60 psi in front tires is correct for both models.
It was more of a general statement.
Nope.From what I've read dually and single rear wheel trucks respectively have the same front axle weight ratings. So 60 psi in front tires is correct for both models.
Nope.
Dually trucks run a different tire size than the SRW 3500’s. Different tire sizes have different load ratings at different inflation pressures. The tire load and inflation tables will verify this.
I need to clarify my post. The weight on the front axle for my model truck is the same for either a single or a dually at 4960-65 lbs.
And, at 4950-65 lbs the dually front 235/80R17 tires are safe at 60 PSI.
However you are not going to like the tire wear and/or wear pattern.
I agree. I waited to weigh mine until I installed my shell and had the truck loaded with my normal stuff.My 18 DRW had a weight on a CAT scale weight of 5660, almost 600lb heavier than the chart weights you refer too. For that weight the 235/80r17 requires over 70psi (2805) but less than 75 (2940). Extrapolation between the load table numbers puts it at 71 psi required. Using the truck advertised weights is not a good thing when trying to calculate tire pressures.
The post was an example, not what I'm running. However, I've run at 65 PSI front and rear on all of my 1 ton trucks (when not towing) and have never had tire wear or wear pattern problems.However you are not going to like the tire wear and/or wear pattern.
Generally speaking far more people run over inflated fronts than underinflated.
agree to disagree. Simply look around while out shopping.
Appearance is deceiving on tires, so I’d never base a broad comment on nothing but appearance.
The tires on my Jeep and wife’s 4Runner always appear under inflated, they aren’t. They are actually slightly higher than they need to be, but not by much.
Take a scale and a tire pressure gauge with you on your shopping trips, you’d likely be surprised.
