Well, I finally got around to weighing my truck at work, and here are the specs:
Front = 4060 lbs
Rear = 2840 lbs
Now, my tires are 285/75r16s which are rated for 3305 lbs at 65 PSI max. When I run the forumla, I get the following results:
Front
(4060 lbs / 2 )/(3305 lbs) * 65 PSI = 40 PSI
Rear
(2840 lbs / 2 )/(3305 lbs) * 65 PSI = 28 PSI
40 PSI for the front sounds OK, but does the 28 PSI sound a little low? I'm currently running 40 PSI all around. Probably a little too much for the rear.
Scott Collins
'98 Ram 2500 4x4 12 Valve Cummins.
Renton, WA
Front = 4060 lbs
Rear = 2840 lbs
Front
Rear
Scott Collins
Renton, WA
