Find a truck scales and get your truck weighed, The scales should tell you your front, rear & combined weights. then look at the rating on your tires. (Should be something like 3042 @ 80 psi for singles and different # for duals)
Use the 80 on the door for this to work.
Take your axle weight and divide it by the # of tires you have; then divide the per tire weight by the rating and multiply that by the max tire pressure (80 psi).
For example, my 2500's rear axle weighs 3,300 lbs and my tires are each rated at 3042 lbs @ 80 psi. To calc the tire pressure; (1650/3042) x 80 psi = 43. 4 psi. The front axle weighs 4,300 lbs, so the tire press is (2150/3042) x 80 psi = 56. 5 psi.
Barry Horner
Lake Forest
Orange County, Ca
2001, SLT+, ETH, 6 speed, White quad cab, short bed, Sport, 2wd , 3:54 anti spin, Camper Special with trailer tow, 16x8 Forged Aluminum with 265x75 tires, Fog lights, Audio controls steering wheel mounted, AM/FM cassette with CD, Travel Convenience group, Keyless entry with remote, Leather agate heated seats. Line-X bed liner. ARE LS 2 tonneau cover. Pillar mount boost and EGT. EDGE EZ and McLeod clutch.
