Tire size calibration?
Scotty II and Uni Filters
Removing threaded plugs from Weld wheels
Ok what unit should i use to calibrate for larger tires? There are a couple out there, seeing who has had the best luck with what?
I think your dealer can do it for free or for a modest cost THAT IS IF YOU HAVE A GOOD dealer? Mine did it for me for free Good luck as for after market I can't answer so I will shut up now :cool: :D goood luck and think spring Oo.
I used the Superchip tuner,it's also a tuner /code reader. Some say it dosen't make as much power as the "boxes" but you don't have to get into the wiring harness.
guys, i was probably getting the CaTCHER ECM. If i have the dealer do it, do they have to go into the ecm at all? Just want to make sure.
No they shouldn't go into the ECM, the tire size is under the ABS menu.
PHP:
"I used the Superchip tuner,it's also a tuner /code reader. Some say it dosen't make as much power as the "boxes" but you don't have to get into the wiring harness. "
Cigar John,
Do you have the part number for Superchip tuner? All I see is "tuners" for gassers not diesels.
Thanks,
Brian
BrianWalker said:
PHP:
Cigar John,
Thanks,
Brian
Part # 3705 Max Micro Tuner 1998. 5-2002 5. 9L Cummins
