Tire Size = Rpm
Oil Pan leak
Star Wheel( I can't remember)
What is the formula to find out the rpm with diffrent tire sizes,and gear ratios?
Most of my driving is highway miles,pulling a trailer,GCVW 26,000,the truck pulls hills very well with this combination,but when empty at
75mph-2200rpm = 16mpg,
68mph-1900rpm = 19mpg.
What I would like to do is run a taller tire so that when Im at 75mph the rpm is at 1900 so that maybe it will get 19mpg, is this possible or would the tire have to be huge to achive this ratio? Also would it have a drastic effect on pulling? And finally how do you get the speedometer recalibrated? TIA.
What is your current gear ratio and tire size? As far as the formula... Somebody will post it as I can't remember the web site.
Thanks for the link,but I dont know what 5th gear ratio is in a five speed,rear gear is 354 and tire size is 235-85-16. sorry about the lack of info I forgot to click (show sig). :eek:
Tragicwagon,
I think you will find that trying to change your gear ratios significantly via the tires won't work well. I have about the biggest tires you can put on our trucks without worrying about something rubbing. Here are the numbers I got with my truck:
Stock Aluminum Wheels:
Michelin LTX A/S 265/75R16 - Load Range E
MPH RPM
50 1375
55 1500
60 1650
65 1800
70 1950
75 2125
Rickson Wheels:
Toyo M-608Z 245/70R19. 5 - Load Range G
MPH RPM
50 1300
55 1450
60 1600
65 1750
70 1900
75 2050
As you can see, the RPM's at 75 mph only changed from 2125 rpm to 2050 rpm. I did not see any change in my fuel mileage. My odometer/speedometer was corrected for the new tire size.
If you want a substantial change in your gear ratios, you'll need to add an overdrive transmission. I hope to do that someday, but not soon.
Here are the transmission ratios, in case you need them:
47RE automatic
1st 2. 45
2nd 1. 45
3rd 1. 00
4th 0. 69
Rev 2. 21
NV4500 HD (5-speed)
1st 5. 61
2nd 3. 04
3rd 1. 67
4th 1. 00
5th 0. 74
Rev 5. 61
NV5600 (6-speed)
1st 5. 63
2nd 3. 38
3rd 2. 04
4th 1. 39
5th 1. 00
6th 0. 73
Rev 5. 63
Good luck with it all.
Loren
fuel mileage
I have an auto with 355s and 34. 4 in tires. at 65 im spinning 1600 rpms. I think that you will find your mileage isnt dictated by rpm but by the amount of energy required to overcome the wind resistance at speeds above 60 mph. in my opinion speed equals mileage not rpm
Thanks for all the help fellas,but after reading Fritzs ram page I guess Ill leave well enough alone. It says you cant put any thing larger than 235-85-16 without adding spacers between the rear wheels,the way tires are sized to get taller you must go wider. Im not sure about all this so if any one has first hand experience fell free to chime in.
