Originally posted by lawdog
Do not forget, when calculating your mileage, you can not go on what the odometer says when you have a larger tire. You will have to get into that math stuff and figure the difference in circumferance of the tires and figure what percent the difference there is in the tires then add that percent to your milage. I had 285/75r16's on my 2000 CTD Auto. I had an issue with mileage, and had a tech from JTE (Jeep - Truck Engineering) diesel lab and 2 from Cummins out to look at the truck at the dealer. They hooked their fancy (scary) computers to the truck and read the computer... ... This was real spooky as they said "Oh I see you have gone 100 mph in this truck :--) , They said that I had used X amout of gallons of fuel, that X % of the miles driven were between X rpm ranges, and that X % of the miles were towing. They said that by fuel flow they can tell when towing, or with weight heavier than just the truck alone. Anyways, they said ADD 4% to my milage figures for the increased size tires from 265's to the 285's... The larger tires were the FIrst thing they said when the approached the truck.....
