Hey!!! Throw up some more pics of that rig!!! That looks great!! ... well other than I'm not a fan of running 2 different styles of side mirrors simultaneously
I'll probably pull the towing mirrors off, I just haven't gotten around to it. I won't be doing any towing anytime soon, anyway. I just pulled the heads off the normal mirrors when I put the towing ones one; I was in a hurry.
I agree... I like a low-slung big tire look.
It's the only way to go!
I've used the Bushwacker cut-out flares in the past, but I don't know if I'd do that again. They quit producing them for the 1st gens, and availability may be slim. I did like how they looked though...
I thought about getting those, but I don't think they would provide enough room for what I need. I'm probably going bigger when these tires are done, and like I said, I'm not lifting it any higher.
If I were you, I'd get a set of stock
rear fender flares, and put them on the front. That would give you ~ 1. 5 - 2" more clearance in front and behind the rear tire.
Have you tried trimming/forming the sheet metal before? It's initially a little scary, but the metal works really well, and it's pretty easy to do. Using the rear flares on the front will give you a little "cover up" area as well, if it doesn't turn out perfect.
I trimmed the fenders on my CJ5, but there was no inner fender to deal with. That's my hesitation with the Dodge; getting the inner fenders opened up and matching the outers.
FWIW, this was trimming the fenders to be able to stuff 37 Toyos under my '06:
--Eric
