2nd Gen Non-Engine/Transmission Tire Wear, Who runs correct tire pressure?
2nd Gen Non-Engine/Transmission crew cab conversion
Engine/Transmission (1998.5 - 2002) GOTTA freakin LOVE IT!
Last time I bought tires I noticed the Cooper tires were said to wear evenly if set to the correct pressure. I called a tech at Cooper and he enlighted me a little on tire pressure. There is an association of manufacturers and tires are built to standards prescribed for various size and ratings. I went to the Goodyear site and poked around until I found a tech document that included inflation charts for the 255-85/16 tire size that I have been running. I had my truck scaled at the local landfill and guess what, I had already determined through trial and error (and 3 sets of tires) the correct pressures for my truck. I was dead on!
I have since had several friends do this and they are all amazed at the even tire wear they now enjoy. These are all different brands and sizes of tires.
When I bought my last set of Coopers I told the guy to put the fronts at 53psi and the rears at 35psi. Hah! They refused, stating that the tires would come off the rim at 35psi. I asked him very nicely how long he had been in the tire business. I then proceeded to look in his reference manual, from the association, and give him an education. He agreed. On the way out of the lot a well meaning young tech came running out and told me that low pressures were not safe. I thanked him for his concern and told him to ask his boss to show him the table.
A few thoughts have occured to me since that time. 1) Do the tire people want your tires to last you a long time? 2) how many people mask problems by rotating the tires all of time? Think about it. Do you want them to wear a long time or are you happy if wear quickly but in sync with each other? If you rotate them constantly you won't have much luck reacting to wear patterns.
3) How many TDR members know about the inflation charts? My first glimpse of a chart was the one that came with my truck in 96 and I thought it was just for the GY tires on the truck. Forget the sticker on the door jamb.
When I last rotated my tires they told me I ran to much pressure. I was up around 65-70lbs. If I dont run that much in the rear when I pull a trailor (gooseneck) they squat bad and I hate that plus its not safe.
They told me to run 35-40 empty and 65 when towning. I would do that but I'm not changing my air pressure every time I hook on. I would spend more time changing air pressure then anything else.
Its all boils down to what a guy is doing with his CTD. Yes I agree I run way to high of pressure but I need the tires to hold up.
I change mine up and down. I found a air hose with a 6” Dual - 1/4” Female NPT Air Chuck, built in pressure gauge, and release button at TSC for about $30. The air compressor was a few $$ more ;) The air hose really makes setting the pressure in tires a 5 minute job.
Tire Gauge - Industrial Grade w/ Inflator
[/IMG]#ad
The MP5142, Combination Tire Gauge and Inflator connects directly to Standard Automotive style Stem Valves (Schrader Valves) and gives you the option to add air while checking pressure. The Industrial style read-out gives you exact air measurements every time, while the dual air chuck helps you fit into the most awkward of places. This unit screws directly onto any Air Hose with a 1/4" Male Air Inlet and requires Teflon Tape (MP5136). This unit does not fit Presta or Woods valves (found on some bicycle tubes). Practical and popular!
Model MP514200AV
PRICE: $33. 00
For Sales Support
Call 1-800-224-3258
A air pressure formula was posted here a few years ago that included your weights. According to the formula it seems that a lot of empty trucks, mine included, take 65 in the front and 55 in the rear.
45 in the rear causes my truck to bounce on the concrete freeways but nice and smooth on rough roads :confused: So I run my rears at 60. I have over 70k on my Michelin XPS street tread 235's. I rotate baby! :p
I still have the original Michelin M/S tires from the factory. I have 70600 miles, and have rotated the tires at every oil/oil filter change (~5K miles). I usually run between 45 - 50 PSI in all 4 tires, I usually keep all 4 at the same level. I do rotate the spare into service every time, so that counts as well, but these darn tires are never going to wear out... I rarely haul or tow much, and 95% of my driving is pavement. I am certain I have at least another 40 - 50K in these tires...
Guess maybe I have been extremely lucky :D
Now if only I could get the same tires in a 35" version when these finally do wear out. I'd be Oo. Oo. Oo.
I have used the formula and gotten the wear expected by the manufacture.
Tom - You better watch out - Your are going to get Sun cracks and rot before you wear them out ;-)
Here's a good resource:
http://www.trucktires.com/library/technical/loadinfl/index.asp
The last link on this page is three zipped PDFs of the load inflation tables for light truck tires - they go all the way to LT315/75R16 and are croscharted to load range E.
Once I found this chart back in 1999, I followed the chart for my truck and tires (stock size LT215/85R16E) and my tires wear MUCH better than before. I got three years of service out of a set of Bridgestone M773 commercial all-terrains, and have now put a year and a half on Michelin LTX M/S Commercial tires now that I do a lot more highway work (75 miles a day). The tires, in fact, have almost 30,000 miles on them and the 4 rears still look brand new.
My o1 came with a booklet from Michelin that has a weight chart in it. I have been going by that and seem to be getting pretty good mileage. You guys that are getting 70K plus on your tires are probably getting 30mpg on your fuel!!
5x up front and 4x out back, works for me.
Autocrossing and roadracing learned me something about tire inflation.
I run 115psi each tire on one of my bicycles and 30 on another. Well, the 115 tires are 21mm wide and the others are 2. 4 inches! nebbermind. :p
I'm currently running 65 pounds all the way around. My LTX M/S's have 33000 miles on them and look like they easily have another 30,000 or more left in them. But I doubt if my 2500 wears the tires as bad as a 3500.
