Tires and Dyno Runs
Does Fuel additive help or hurt during break in????
Air Bags?
I was just thinking about the performance difference when I change from 245/75R16 to 285/75R16. There was a noticeable drop in performance when I went to the 285's. It seems to me that this would transfer into your Dyno runs also.
Does anyone know for sure if this is correct? And how much will it change your Dyno numbers?
<font color=blue>"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Pro-flap mud flaps with Stainless Cummins "C" add to rear flaps, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, HOT Power Edge, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), 285/75R16 Cooper A/T's, Navigator 55w backup lights. </font>
<URL=http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9265455><font color=red>My 99 Dodge Cummins</URL></font>
<URL=http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9815423><font color=green>BD Dyno Days 10/28/00</URL></font>
<font color=purple>
Things to come; The clutch has let me know it is going to need attention very soon!
Pyro, 50# Boost and Fuel Pressure gauges (have Ultra lites will install shortly), PE EZ timing module and injectors (have Bully Dog step III injectors ordered), have 2 KC Daylighters (Stainless with 385,000 candlepower each), have 2 KC Fog lamps(Stainless 100w each) and waiting for Smittybilt Stainless Outland Brush Guard to arrive, then will mount guard and lights.
NRA Life Member! (Need to protect our rights and FREEDOM!!)</font><font size=-2>
[This message has been edited by BIG BOB (edited 12-18-2000). ]
Big Bob,
I was just talking about that on friday to Brad and RPM in Ca.
Thats where HAVC and My6eatsV8's do alot of dyno testing and Brad could help you answer your ?.
I run 35' tires and was wikking to go back the stock size for a dyno but it was mention that it might not make that much of a differance.
I'm willing to try this next Fri when we dyno some chips on the 00 F350 PSD of mine,(dont worry we have and 01 SLT 4x4 2500 Cummins quad cab that the wife drives)
If I recall correctly we have seen where dyno testing in 5th works better then 4th gear. This is because in 5th the boost gets a tad higher from the greater load. More boost usually means more horsepower.
I would think that large tires would be similiar in effect. A taller tire/gear ratio should cause the engine to develop more boost/horsepower. If a lower ratio were beneficial then dyno testing in 3rd would produce the best numbers.
Once again I have to wonder if this lower gear ratio being beneficial isn't misplaced naturally aspirated gasser science. Remember, the peak torque on the Cummins engine is achieved at below 2000 rpms.
Nowel/Performance Diesel
