Originally posted by Fish
CAnderson
This is all I've seen recently about prices for that unit.
Walker RV- OKC says the MSRP is 48K
The sales manager says their actual (invoice?) is 38K
Without any heated negotiating:
Trailer cost $36,900
Hitch/brake controller installation - $425 – non slider hitch,
Tekonsha (sp) break controller.
You might want to consider a smaller trailer though. I have the same truck without the modifications, and after doing the numbers, regretfully went to a 28E33 in order to be legal. You will be considerably over your Max GVWR because the king pin weight will be between 1720 and 2400 depending on how much junk you throw in, and very close to max on your rear axles and springs unless you have upgraded them. The max for stock 245/16 E tires is 6160, springs 6200 and axles 6500. Your engine mods will pull it handily but stopping and stability may be a problem. The gurus on this forum recommend a 10,000 max GVWR trailer for a 2500. Good Luck!
