Engine/Transmission (1998.5 - 2002) ? to all the guys running 1/2 fuel lines & non stock filters
Engine/Transmission (1994 - 1998) "1.5 mm" engraved by afc
Engine/Transmission (1994 - 1998) B-1 Bomber
tommorrow i'm putting a holley blue on with 1/2 lines and pickup and looseing the stock lift pump b/c it bit the dust. .
what did you'll do about the stock return... did you leave it alone or use the stock feed as the return...
i also want to get rid of the stock filter... but what happens when you unplug the two plugs on it?
the truck is a 2000. .
I Have 3/8" lines; No problem Unplugging Filter
I have FASS w/ 3/8" lines feeding from tank to FASS to injection pump. I kept return lines stock no problem.
I didn't set any codes disconnecting plugs from filter housing.
Wiredawg
leave the stock return line hooked up--there's no need to touch it--if your pressure is to high then add a regulator with a separate return line---the two electrical connections are for the fuel heater and water in fuel sensor, so it shouldn't hurt to leave them disconnected--I'd use the oem wire that provides power to the stock pump to run a 30 amp relay to power the new relocated pump----chris
