Details here: TDR Privileges
I just install #11 tst plate and slid it all the way forward when installing, the truck runs great but boost seems to be about 40psi is this going to hurt anything?The truck is a 98 manuel trans if you need to know. Thanks Jason
So if i slid the plate back a bit will the boost go down or is there a way to adjust the boost to lower it without affecting egts?The truck is almost stock accept for #11 plate,kn air filter,walker muffler with no cat,so is it the plate being all the way forward causing the higher boost. Thanks Jason
Ted would know better than me, but I thought 36 was about as high as you want to go with an HX35 to keep it in its' efficiency map. I think 40 is a little too much.
What's a guy supposed to do with a 16cm no wastegate housing? Maybe I can lower my egt a smidge if I can bring the boost down somehow but I think I'm SOL with this housing.
I Know, I need some manifold leaks. Anyone have a leak they don't want?
