The rest of the story...
Basically what I just said, but with all the supporting knowledge I lack. .
Thanks sdstriper for the knowledge!
Ken
Grid Heater Control Modules preheat cycle, ignition key on, before cranking the engine. Grid Heater Control Modules with a serial number below 0080000A do not preheat cycle unless it is 15*F or below. That serial number and/or higher has a preheat cycle from 15* to 59*. They all post heat cycle according to the manual, no other info on post heat.
Serial numbers below 0080000A
15* to 59* No preheat
0* to 15* fifteen seconds preheat
-15* to 0* seventeen and half seconds preheat
below -15* twenty seconds preheat
Your block heater that you plug into 120v heats the engine coolant in the block which keeps the oil warm etc. The grid heater utilizes a sensor in the head IIRC, it's called a Thermistor Sensor.
Fuel anti-gel additives are available at any decent truck stop. I have been using Howes which is a lube and antigel. I did have an incident though and probably will change brands If I run out this bottle before the weather breaks. Power Service and/or Diesel911 is what got me out of a gel situation recently, so that is my next choice.
#1 diesel fuel is thinner and less likely to gel than #2, if you pay attention at the pumps in these colder climates, you may notice it or a blend of the two fuels. #1 has noticably less power too.
Power Service anti gel additive and for $8 a bottle of Diesel 911 if your worried about it, just in case...
Ken
