I have a Palm TX and decided to get the PalmOne TomTom software (same software as their stand alone GPS devices). I've used it several times, over the past couple of months, and have come to the conclusion that it is a real turkey.
I would never trust this device, while towing my 5th wheel, in an area that I was unfamiliar with. It will try to route you down dead end roads, to get back on course. Programing an itinerary is a real adventure. The process is very labor intensive, and even when you put in several "via's" to select the route you want to go, it will ignore the via's. This is especially true when you deviate from the "fastest route. " It will try to take you back to that route even when established on the alternate route. I think this program was meant to be used to find POI's in big cities as the accuracy of the information goes severely downhill when you get out in the country.
Also, the Palm TX screen is just not bright enough to use in full daylight.
If anyone else has had better luck with this program, please let me know, but so far it has been all hype and little results...
