Engine/Transmission (1998.5 - 2002) Ton of white smoke
Engine/Transmission (1998.5 - 2002) Fuel filter change
2nd Gen Non-Engine/Transmission tow hooks for 2wd
I think I got problems :mad: My truck is pumping white smoke out of the exhaust. At idle (when it's warm) if I goose it, I'll get a small cloud of white smoke. When I decelerate from high RPM to slow the truck down- the truck pumps out a good trail of white smoke.
I replaced the fuel filter, air filter, and lift pump... No change.
I tried unplugging the EZ... No change
I'm guessing it is a turbo bearing seal, but I'd like your input.
Also, the O-ring on my oil filler cap went out so my engine has a good spraying of oil on it. Could I have a vacuum leak that is sucking in oil? Please. . ?
My truck runs as strong as ever. Egts are fine. Temp is same 190
TIA
Thanks, Any ideas on how I could check?
I just checked, and there is no oil coming out of the exhaust pipe... So maybe it's not a turbo bearing seal?
Thanks for the suggestions guys;
It turns out that the hose I used to relocate the puke bottle had collapsed. I did the relocation about 6 mos ago so it was the farthes thing from my mind. I feel like an idiot.
