Before you spend big $$ for that BG 400 pump, you should know that most of those big pumps aren't meant for daily street use. I was reading about the Holley Volumax 160 & 250 pumps, the 250 is drag use only. The 160 has 2, 1/2" inlets and both must be able to get fuel. Scott mentioned his Mallory, (probably a Comp 140)140 GPH, preset for around 14 PSI, and good for daily use, good choice. Another member has a BG HR 220 pump, it's the same $$ as the Mallory with a bit more GPH. BTW, the Holley 160 is around $40 more than either the BG or Mallory. I hope some of this helps save you a dollar or 2.
AL
01~3500QC,4X,Sport-Silver,eth~dee,3. 54,Line-X
