Ok, I just installed a new VP-44, rebuilt Bosch Injectors with Edge Stage 3 nozzles, new turbo, new IAT, and 5 inch stacks. I have not tapped the VP-44 wire for the juice w/attitude module yet (new pump warranty, etc. . ) The problem is the truck smokes like a freight train under just a little load or moderate acceleration, the smoke thins out after you get to speed. I am running the attitude on 1. The new turbo still only gets to 20 psi max. I thought the edge had boost fooling.
Is all the smoke and soot normal under the described conditions? If not what should I check for.
