Took out Super Mentals
Torque Converter
Newbie
Joseph Donnelly
Hmmm, someone else took out his 370s and put in 160 hp injectors #ad
Well, my poor old Ram has been feeling pretty Sickly lately with only 609 hp #ad
I figured it was time to take out my big DD Super Mental injectors, but "maybe" not go smaller. . . I stopped by Diesel Dynamics and talked about the low power problem with Lawrence. He cooked up a special set of BLACK INJECTORS for Sickly, so I took out the Super Mentals and slipped in those black bad boys.
WOW #ad
Sickly feels better already #ad
Almost ready for May Madness, I hope. #ad
Did these give you the extra 91 hp you were looking for??? I am beginning to think that 750 hp on #2 only is within reach for us 12 valver's.
Let me know if those Super Mental's need a new home. I promise to feed them well!
88 GMC CREW CAB 4X4 89 6BT,NO INTERCOOLER YET,AUTO METER LIQUID FILLED GAUGES,NV4500,NP205,4. 10's,35 BFGA/TKO,6" LIFT,DETROIT LOCKER,16CM,K&N,3. 5 EXHAUST,BD "PRINCE OF DARKNESS"INJECTORS 96 215 hp on the way. J. Mason
I had to give the SMs back to Lawrence since he was holding Sickly's new black injectors hostage #ad
and Sickly really needed the power #ad
Haven't dyno'ed yet so don't know how much power the poor old Ram has. Maybe it will have enough hp to crawl up onto the roller all by itself for May Madness #ad
Experimentation continues on the 12 and 24 valve fronts (see the Stage 6 thread on the overvalved forum). Lawrence is tired of the 24 valvers having to stay on the 500 hp porch while the 600 hp 12 valve Rams romp #ad
It looks like the new Stage 6 package will be what he needs #ad
Hey J Donnelly, when is May Madness ??? I would like to come out and check it out. Thanks
DD
'96 12valve 4x4, White SLT Long Bed. Kenwood CD player w/100 watt custom made subwoofer built under back seat. DTT TC & VB (WOW !!) TST #8 (230/605). Moster tip from GENO'S, ISSPRO Guages on the "A" pillar. "TNT" sprayed in bedliner-and sprayed along lower rocker panel and in the front door threshold. Off to a good start!! MORE TO COME !!
Joe,
Do you think if I parked my truck next to Sickly it would catch the same HP disease? #ad
1996 Dodge 2500 4X4 SC, SLT,Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights.
