3:07
I would be very pleased to find that I am completely wrong but If you find a source for the 3:07, I believe that you will have found the end of the rainbow. There are some used available from time to time that are on the TDR classified. But new???? Back in 81 when I was trying to get a Perkins operational in a Ford, I was also in search of the 3:07. While there is literature that indicates that these are available for Dana axles back before Dodges used them, I never found one.
Making a run of ring and pinions is a very involved manufacturing chore. Unless you have a customer who wants more than a 1000, it is not going to be profitable to set up the equipment required to turn them out. To my knowledge, Dodge is the only manufacturer who actually ever had the 3:07 in a truck. If enough people wanted to buy a 3:07, the parts could be turned out by several gear companys who have the capacity.
In my way of thinking, this would be best done for the Dana 80. This would offer the best of several possibilities. The additional capacity of the 80 is what the Cummins needed in the first place. Of course the ratio choice is also wrapped in the overall choice of how many gears, how stout to make the drive shaft, how stout to make the drive axles and other considerations of rpm and power transmission from the clutch to the wheels. In as much as the trucks are used in such a wide variety of applications and by individuals who apply their personal prefferences to the standard package, Dodge has setteled on the middle ground of 3:50 to 4:11 axle ratios. The ongoing move to more gears has now arrived at six, at least as an option, for the new model.
In discussions with Eaton engineers in 81 with regard to two speed axles for the "light" duty trucks, the comment was that the industry would be using eight speed trannys in a couple of years. Well I guess a couple of years have passed but no eight speed in the class of the Dodge trucks.
It has been my contention that the two speed is right for the heavier applications that the trucks are subjected to. At some point of transmission reduction, you have the capacity to twist the drive line from the truck just pulling off with the load unless you go to a drive line that is in the capacity of a Mack truck. The twospeed gets the reduction past the drive line and past the ring and pionion. Alas, most people who drive a two speed will crash it before they learn how to drive with it. It is also in the 5:75 range.
I expect that this is longer than allowed for a post now so will sign off.
1stgen4evr
James McPherson
