HHhuntitall
Well, no offense, but the amount of compression loss with the thicker head gasket is somewhat non-existant. Boring +.020 will MORE than compensate for any compression loss... the use of the thicker gasket is for valve clearance, as remember, you are cutting off the block AND head to get a new, flat bonding surface, plus adding more valve lift and duration. Adding valve lift allows more air for a longer period, but you want the clearance. It's just a safe practice I follow, so there's no valve contact. Fly cutting the pistons is much more expensive than a thicker headgasket you are already paying for. Just my opinion. If you are using a head and block that have never been decked, you probably won't have much of a problem, but checking is always a good idea before turning the engine over and finding out the hard (hitting) way.
