Where is it? I'm trying to remove the check valve to get better flow thru the cooler (per Bill K. ).
I just pulled both the quick connect lines going to the transmission cooler and saw no sign of a check valve. I could blow air thru the cooler from either direction. I'm referring to the connectors with the clips on then where the solid silver cooler line connects to the rubber hose that goes to the cooler. I have the shop manual and see the reference to the converter drainback valve but sure don't see where it is.
Any ideas where to look?
Thanks, Chuck
Thanks, Chuck
