A-bomb:
I recently went through all this on
my 96' which just recently turned
over 100,000 miles. When the truck
had about 15,000 miles on it I had
the "Trans-Go" Shift Kit installed
in the truck. AFTER that I had Mark
Chapple at TST install the #6 cam plate
(250H. P. ). I had no problems with the
stock TC and valve body until I reached
about 98,000 miles. I regularly tow a
racing trailer (8,000-9,000lbs. ) all
over the Mid-Atlantic as well as a 20'
flatbed with a MF tractor(10,000lbs. )
and believe me I "roll" when I am
towing these trailers!
Anyway, as I said, at about 98,000
miles I noticed that the TC began to
"shudder" and slip when towing in the
Smoky Mountains (I-77, WV etc. 4-5%
grades)on hot, humid days. At that
point I knew I had to upgrade.
"Scheid Diesel" in Effingham, Ill.
did the transmission work for me. They
did an EXCELLENT JOB installing
a "Pro-Torque" TC and complete
"BD Valve Body" along with a "Mag
Hytec" Transmission Pan and updat-
ing those pesky transmission fluid lines.
Let me tell you my stock TC just
about had it! It was stained blue
from the excess heat and they felt
it would not have been long before
it failed! You can contact Rick or
Brian at their Effingham, Ill. store
@ 1-800-669-1934. They are really
great people to deal with!!
However, as you probably read in my
post "BD Pressure Loc" question this
new torque converter has a stall speed
of 1600 compared to 2000 for the stock
TC. I now have a "flat spot" or "2-3
second lag" when I accelerate from a
dead stop until the engine reaches
about 1300 RPM. It will then take
off hard and accelerate smoothly
to governor speed. Other TDR memebrs
have had the same problems with the
low stall converters (i. e. : KoaMan,
RobG, bigkavr). It seems that the
lower the stall speed, the worse it
is. As you also read, the 370 inj.
Koa Man installed completely solved
that problem. I am getting ready to
do the same thing.
Before doing anything, call around
to the various manafacturers and see
if you can't get them to "custom
build" you a TC like you want it
for what YOU are doing. Piers at
BD has done ALOT of work on this
and is very helpful(1-800-887-5030).
Also read the 12 Valve Post "Torque
Converter Choice. "
Sorry for such a long post, but I
wanted to explain my situation to
you. Hope this helps you! E-mail
me if you want to. (gray tank@msn.
com. ) Good luck!
John_P.
Red '96 4x4 2500 Auto 3. 54, TST #5, Pump Mods, Banks Exhaust, Prime Loc, Cummins Chrome Kit, Pro-Torque Converter, BD Valve Body, Sendel 16" Alum Wheels w/ 33" BFGs
