Engine/Transmission (1998.5 - 2002) Torque converter unlocking at pull
Engine/Transmission (1994 - 1998) will fuel plate wear pump?
2nd Gen Non-Engine/Transmission HELP!! Front shock removal - 2001
Pulled in a truck pull Friday night and had what I think was the converter locking and unlocking. To people watching it sounded like a miss but had an issue when Dave Goerend installed the new transmission it would lock and unlock with his scan tool on. He wrapped the wires from the alternator, installed a noise filter all to no avail until he disconnected the scan tool, then it stopped. It has come back when pulling the skid loader, tried the apps reset and thought was gone till Friday night. I have a FASS and fuel pressure didn't drop below 14 lbs so fuel starvation shouldn't be the problem. 140 hp injectors and a comp won't be to much for a FASS will it? Also have a Blue Chip Diesel FED EX pump could it be the 2700 RPM limit on that? It's one year old. Dave also suggested a reflash by the dealer. My truck was an early 02 production would that help and do they charge for the reflash? Any help please! DW
Any chance the truck is defueling at all, even intermittantly, causing the t/c to unlock? Bad APPS, bad connection somewhere,... ... Is the VP OK? Good grounds all around?
Since the fuel pressure is staying up, the FASS is probably keeping up just fine.
Dave Goerend checked all the grounds when I was at his shop. Just read a post on the true FED EX pumps that defuel at 2600. The track is only 300' long its hard to take your eyes off the track and look at gauges.
