My 2003 with 212K on the clock has a problem with the torque convertor. Sometimes it will not unlock unless I slip it into neutral. The truck is used mostly for highway use and pulls trailers that weigh less than 9000 lbs occasionally. I have used Amsoil synthetic ATF since the first full fluid change and it still seems to shift fine. I have had the torque convertor lock up solanoid changed and saw no improvement.
I also have an occasional problem with the cruise control cutting off (light stays on on the dash) and I am getting a "lamp out" warning occasionally.
Any suggestions? Could any of these problems be related?
