Originally posted by KennyM
Here is a link to the real numbers, these are from the EDGE web site.
http://www.edgeproductsinc.com/chart_dura.html
The D-Dud has proof it's a DUD.
Ken
Learn how to read a dyno sheet, The truck that Edge dynoed is obviously an auto. The higher the rpm when you start a run the lower your torque numbers will be. The HO Cummins is only available with a standard so you can start the run a lot earlier than 2250rpm and get a lot more accurate reading.
I want to see a six speed Duramax vs. HO Cummins on the same dyno the same day and started at the same rpm. I guarantee the Duramax would have more power to the rear wheels.
