On my 98. 5, would this be the blk/tan wire from ECM pin 30 and 49 to the front of the engine and the dark blue from PCM C3 pin 25 to the alternator and the transmission relay? Any instructions?
Not sure of the colors or if it is different from 01 to the 98. There is a wire that comes off the passenger side battery and runs over the top of the alternator and into the harness that contains the charge wire from the alternator.
Dodges fix was to pull the APPS wires out and run them in a seperate harness. Its a whole lot easier to cut and rerun the 2 wires seperately. We ran the ground wire back to the firewall and over then down into the narness where it splits on the driver side. Ran the charge wire over the radiator support and down to the connection below the driver side battery.
That totally eliminated the problem where wrapping the wires in tin foil was only partially successful. Still have an intemittent problem with it only under very special circumstances, namely when driving thru large puddles of water. It will do the same thing with much less frequency than before but it is the same problem. I suspect a harness has a crack in a wire somewhere that is letting moisture in. As soon as it dries out the problem disappears. Its worth check all your harnesses underneath and in the engine compartment for possible problems also.
Drove the stupid thing for 45 minutes in the rain the other day and it never did its little dance. Go figure.
So is the installation of the BD "noise filter" on my '03 that seems to have cured my problem just a temporary fix?
Everyone I tried to fix with the filter always came back. Albeit less of a problem than before, but, it eventually came back. The filter is not elminating the noise just masking it until it cannot do it anymore. Electronics get weak over time and filters are notorious for not staying in balance for long.
Some have gone years with just the filter, or tin foil, and only rarely have a glitch. Others have gone 30 days and its back to the same thing. The efficacy of the filter is dependent on other things and there is no way to gauage how effective for how long it will be on every single truck.
The problem is caused by noise generated in the charge AND ground wire that runs in the harness next to the APPS wires. That feeds a false signal to the PCM that causes it to play with lockup. We have mapped this on a scope and it is ugly at times. The only way to stop it is remove the source permanently.
