The only way that I know to find the stock position of the factory fuel plate is to look at the lock washer marks on the original fuel plate, that is if you still have it.
Radixr is very correct about the use of the template.
What I personally do to set my fuel plate position is to adjust accordingly to the exhaust gas temperature. I reference 1300 degrees as max, therefore I set the plate so that during my hardest pull towing I don't go over 1200 (sea level) This allows me a margin of 100 degrees when I'm above sea level, which is needed. This doesn't provide the best set of the pants fun, but it does keep your engine within, what I consider, acceptable operation parameters.
This is when additional modification other then fueling show their benefit (turbos, exhaust, injectors, etc. ). It is very easy to increase the fuel in the 12 valve, which is also a very easy way to get into trouble with Egts. These additional modifications allow for the same fuel plate to be run a little further up the fueling curve before getting into trouble, but not a whole lot more. The fuel plates from TST are designed to be run in the stock location to provide proper EGT control, except for the competition plates which are noted when purchasing. DBR
