TORQUE TUBE What is it and what does it do?
Is it somthing i would use for towing on a 041/2?
Anyone running one with the stock air filter assembly?
ROCKJEEP said:its an enclosed driveline, or torque tube, is really a very effective design.
Its advantages are positive location of the rear end, with no Panhard rods, traction bars, etc needed for stability. Only one U-joint is needed, and it runs in a constant lube shared with the transmission. It was used in many passenger cars so I doubt the "out on the farm" angle. The newest hi-zoot Jags and Aston Martins use a torque tube driveline, so it can't be all that bad.
The main negative on an enclosed driveline, though, is that there are very limited ratios available for the rear end. Also, U-joints are expensive and more complicated to change - and the seal which retains the lube in the tube, when worn, can cause all the transmission lube to drain back into the rear housing, and eventually into the brake drums.
When everything's in good shape, the torque tube is fine for its intended purpose. When it wears out, or we change that purpose, it's a major pain in the rear!![]()
Oh, you ment the air intake.
JR2 said:Just to clear it up, the torque tube is both a drive line system on Unimogs, pinzes etc and a new air intake tube for our truck. Its funny to see both answers here, usually anything outside of diesel pickups is ignored.
