Tow Hooks from Dodge?
First picture test gauges
Howes Lubricator
Does Dodge/Mopar or anyone make tow hooks that can fit on the front of my truck fairly easily? It is not a sport model. Any feedback would be much appreciated. This is my first post and I look forward to many more. :)
Welcome To The TDR!!!
Yes, go to the dodge web page, pick your truck, and wander around in the accessories.
They make tow hooks for the front end.
Matt
Dodge does make tow hooks for the front but they are pretty expensive. You might consider doing what I did, put a hitch on the front of the truck. I went with a draw-tite hitch, it just bolts up and is the same cost as the tow hooks from Dodge. The thing I like about the hitch is that you are pulling on both frame rails so that you don't rack the frame. I have a Warn clevis plug that I carry around to put into the front hitch if I ever need to use it (haven't had to use it to extract myself, but have used it twice to pull others out from the front).
The Dodge hooks are pricey but there are several brackets the are needed to get the hooks below the body. The finish has stood up to 5 years of Wisconsin salt spray without any rust so far, I can't say that for my Hidden Hitch.
