Tow Hooks
Lifted the 03
Registering an 2003 HO/spd. in CA.
Anyone out there remove their front tow hooks on an 03 2500 and want to get rid of them! Mine didn't come with them and neither did my buddies :(
Originally posted by CIverson
Mine didn't either. I bought the tow hook kit from mopar. Gonna install them today while I install my plow.
I am not sure if you can have both the plow subframe and the towhooks on your truck. The reason I say this is because my Fisher dealer informed me that it was a good thing I did not waste the money on the tow hooks because they would have to be removed to install the plow.
Well I just installed the w/ the plow and the tow hooks :)
I understand what he's saying though. The reason is you have to additional plates that go on the outside of each bumper bracket. If you add the mount for the plow it spaces out the bracket so the 2 outside holes don't line up. I simply bolted it all together and drilled out the holes in the support brackets so I could get the bolts in.
I've seen pictures of the boss plow mounts and they actually have a tab incoporated so the outside holes bolt through the plow bracket.
I'm glad it all bolted up for you. I had my plow installed last November and my truck was the first 2003 diesel the guy had seen. They had installed one frame on a Hemi so thats what he based his info on.
