Some of the first Cummins B Series to be used in Pickup Trucks was for Jet Transport, Middlebury, Indiana.
Cummins worked with them supplying engines, they were mostly put in Chevy pickups. They ran them hard and long hauling Jaco RV's all over the USA, Canada, and to Alaska.
It's not bad, just not the ideal way to break in the drivetrain. . the motor loved it! Thou personally I would never go 6500 miles on the first oil change, especially on an EGR motor.
What does the EGR have to do with oil changes?
Recirculating exhaust gas into the cylinders introduces soot which is washed down the cylinder walls into the oil. The regeneration cycle on the 6. 7L Cummins also uses a late fuel injection event to build heat in the exhaust emissions converters and filters - this late injection event results in fuel dilution of the oil. So, by design, there's far more soot and diesel fuel getting into the oil with these engines than with the older 5. 9Ls.
Rusty
The amount of recycled exhaust returned to the combustion cycle is very small, if the truck is worked as designed there will be none to little soot, my 2012 has cleaner oil in it after 5000 miles than my old 2005 5. 9 had at 5000 miles, that small amount of exhaust sent back into the engine doesn't make oil get dirty.
Ummmm... . OK. Whatever you want to believe.![]()
Rusty
Nope, no soot at all.
