Last week I brought my 06 2500 in for some warranty work (check engine light). Since it was in the shop I asked that the rear differential be checked. I explained that the differential has been whining since I bought it. The truck has 13,000 miles. For the first 10K miles I towed a 5000lb TT. Since then I have upgrated to a 9500Lb 5th wheel. When the dealer checked the differential they discovered that the left axle was bent. But that is another story. The story of interest for this thread is technical service bulletin 999925743. I have read many threads on this forum discussing complaints of whinny real axles along with many cautionary notes on using 75w140 synthetic gear oil vs the 75w90 called for in your owners manual. This TSB speaks to overheating concerns expressed by both dealers and owners alike. Quote "Rear axle seems to overheat while driving. Rear axle housing may be be too hot to touch. This is normal operation" unquote. I can personally attest to the fact that the real axle housing runs "hot". But there is more. Quote "normal axle operating temperature is 250-350 degrees" unquote. Lastly the TSB recommends using 75w140 GL5 synthetic oil for any vehicle used for towing. With my truck repaired and running 75w140 I was anxious to see if the whinning would be eliminated. Unfortunatly it was not, reduced yes but still there. At least I have some comfort in knowing that using 75w140 is the preferred lubricant and should offer additional protection over 75w90. More importantly the bent axle was replaced. If it had gone undetected complete failure of the axle bearings was just about guaranteed. Further Muphy's law says the failure will occur when I'm out in the desert, 110deg and 200 miles from nowhere.
Jerry K
Jerry K
