DTT uses the 1996 or 97 output line that has a sender port in it and a custom extension to reach the cooler on the side of the engine. This allows one to measure output temps close to the output of transmission. Things happen fast at this measurement point. I feel the sender in the pan is a waste and have thought about moving to the rear diff.
Chris
i agree that is should be close to the output line of the trans. if i am not mistaking it is the line on the passenger side of the trans and the one that is the outer most line going to the heat exchanger??? i am not sure if its the front or back line on the trans passengerside...
I have an aluminum block that i am going to try and machine a free flowing adapter out of that will not impede the flow of fluid.
