About to do my first real towing with my rig. 3 or 4 2200 mile R. T. "s coming up. Moving out to the Rockies.
Would appreciate any suggestions/comments about my preparations. Will first explain everything I've done/plan to do at this point.
1) Bought a 10,000 GVW car hauler, weight distributing hitch, sway control.
2) transmission is 518 auto.
2. 1) Have added Mag Hytec double deep pan. ( 4 extra quarts of fluid )
2. 2) Have trans temp guage
2. 3) Have factory H. D. cooler under bed. Have bypassed thermal switch.
Installed a manual switch/relay. Plan to turn on at 150 degrees.
2. 4) Have newer flex plate (POD's, tweaks, excessive enthusiasm,DOH!)
2. 5) Will entirely flush, incl. T. C. , and replace ATF.
3) Rear end
3. 1) Have installed "E" load range tires ( 2500 lbs. each X 6).
3. 2) Have air bags
3. 3) Have aftermarket sway bar
3. 4) Will replace Diff fluid. ( Change to synthetic???? )
4) Engine
4. 1) Have new radiator
4. 2) Will cange out 12 cm turbo to 16 cm
4. 2) Will change all fluids filters etc. prior to coming long trip.
Towed it home from lot (50 miles) and barely knew it was there. Empty of course. Some highway, some two lane winding road, some grades, some wind, semi's went by both ways. Feels pretty good so far.
Whaddya think?
Thanks ,Bob
3) Rear end
3. 2) Have air bags
4) Engine
Whaddya think?
Thanks ,Bob
