towing suspension troubles
Higher EGT's while towing
Charging RV Battery
ok, here it is. with the available hp and the heavy 5ver, axle wrap and bounce is TERRIBLE!! all suspension parts are stock, i can no longer handle this. HELP!:mad: ladder bars? shocks? what????:confused:
Do you have a two piece drive shaft? Older 2nd gens with a two piece drive shaft would have vibration starting to move a heavy fifth wheel. Putting a 3/8 or 1/2 inch shim under the drive shaft hanger bearing usually helped.
Go to page 14 of issue 38 of TDR Tom Clayton has you answer. Your post sounds like Tom. :) :cool: Clem
