I am about to pull the trigger to get the Toyo MT 295/70R17 and would like to confirm the following:
1) There will be no tire rub at full lock with no lift and stock rims?
2) Do the MT's give good traction through most of their tire life?
I currently have the Toyo AT 285/70R17. They did great in snow, ice, rain and wore evenly (but quickly). I also liked the load rating 3750 lbs @ 80 psi. However, the AT traction seemed to noticeably diminish when they became 1/2 worn out.
The MT 295's load rating is comparable at 3970 lbs @ 80 psi versus the other Toyo MT sizes at 3195 lbs @ 80 psi.
-Thanks-
-Thanks-
