TPMS for spare tire?
Front end play
Interior Courtesy Lights Time Out
I would like to include my spare tire in my tire rotation. What happens with the TPMS? Will adding a sensor to the spare confuse the system?
NOTE: Your vehicle is equipped with a non-matching full size spare wheel and tire assembly.
1. This spare tire does not have a tire pressure monitoring sensor. Therefore, the TPMS will not monitor the tire pressure in the spare tire.
2. If you install the full size spare tire in place of a road tire that has a pressure below the low-pressure warning limit, upon the next ignition key cycle, a chime will sound and the TPM Telltale Light will still turn ON due to the low tire.
3. However, after driving the vehicle for up to 10 minutes above 15 mph (25 km/h), the TPM Telltale Light will flash on and off for 75 seconds and then remain on solid.
4. For each subsequent ignition key cycle, a chime will sound and the TPM Telltale Light will flash on and off for 75 seconds and then remain on solid.
5. Once you repair or replace the original road tire, and reinstall it on the vehicle in place of the full size spare tire, the TPMS will update automatically and the TPM Telltale Light will turn OFF, as long as no tire pressure is below the low-pressure warning limit in any of the four active road tires. The vehicle may need to be driven for up to 10 minutes above 15 mph (25 km/h) in order for the TPMS to receive this information.
Well, I don't have a TPMS, but it sure doesn't sound good for rotating the spare in. I suspect the system will either ignore or be confused by the extra wheel sensor, so I doubt that's an option.
Is there a way the dealer can disable the TPMS system? I find this unlikely, since it is now illegal to sell a vehicle without a functioning TPMS.
Perhaps the spare-inclusive rotation pattern is another casualty of government oversight? Chances are, the government never bothered to consider that some people might like to use the full size spare. Or swap the tires out during the winter. \
If it were me, I'd probably put the spare on and do my best to ignore the light. A small piece of black tape might be used to cover the light.
Ryan
LOL... . I thought of doing that... . But it pisses me off that I'll have a $45,000 truck riding around with black tape on the gauges, just so I can use my spare.
Amen to that! Blame the Government. After all, without TPMS you'd probably be driving around with 4 perpetually flat tires.
There's probably a way to fool the sensors into acting like they're at normal pressure, but you'd have to dismantle one to play around with it.
What is the "normal" tire pressure anyway? I'm constantly adjusting mine based on load and weather conditions. And I run different pressures front/back. Does that play havoc with the TPMS?
Ryan
TPMS is set for 65 Lbs front or 45/80 rear depending on the position of the light/heavy load switch. I don't know what the threshhold is for the alarm to come on but it seems that the truck always has to be empty or fully loaded.
Here is something to ponder. I have an 18 year old Corvette that has the "optional" TPMS. It has a mind of it's own and lights up when it feels like it so that you think that you may have gotten a flat. The only place to get parts I'm told is a salvage yard because GM dosn't support it any longer. The "fix" according to the support forums is to remove the bulb from the display.
What's going to happen with these trucks as they age? :confused:
Very interesting. Personally, I run 60-65 lb up front and 55-60 lb out back when I'm unloaded. For loads greater than 1000 lb or so I bump the back up to between 70-80 psi.
I don't think I would like this TPMS system. Having said that, I would like to get one some day that merely tells me what the pressure is in each tire. Not an idiot light.
Is there, perhaps, a single fuse or relay that controls the TPMS?
Ryan
Here is the Readers Digest version of TPM on a newer Chrysler.
The sensors "should" be programmed into the wireless control module, wireless ignition node, or whatever it is called in your model truck. Having the ID code input into the module with the scan tool allows the module to identify the wheel position of each tire. But this is not always necessary as the module can identify the tire pressure being broadcast, but not the tire position. Low line monitors do not display the individual pressures on the dash, but they do display on the scan tool (assuming the position of each sensor was programmed). High line monitors that display the tire pressure of each tire have transducers in three of the wheel wells, and can identify the tire position even if rotated. Some vehicles have transmitters in the spare, and remember that dual rear wheels have six sensors. So there is capability in some modules to read five or six tires, but they have to be programmed.
The sensors go to sleep when not moving, but are also "woke" up at key on by the wireless module sending out a message. They also wake up when moving by the rotation of the tire. On a smart system the spare position is known by deduction because it is the one that wakes up at key on, but does not stay awake by rotating. So in theory you can have five sensors, but I have never tried to add one to a system that was not factory equipped with it. The reason you have to drive the at least ten minutes is to make sure the sensors are awake, and have sent messages to the wireless module a minimum number of times. Also the tire pressure thresholds must be set in the module to match the door sticker tire pressures. A wrong threshold setting can cause a TPM light to come on when a tire is not low.
Now here is the description from the FSM for 2008 DH.
The tire pressure monitoring system (TPMS) is designed to operate without loss of function for all OEM tire construction for this vehicle. Tire Pressure Monitoring Sensors, mounted to each road wheel as part of the valve stem, transmit an RF signal indicating their individual pressure to a receiver located in the Wireless Control Module (WCM), commonly referred to as the Sentry Key Remote Entry Module (SKREEM). These transmissions occur approximately once every minute at speeds over 15 mph (24 km/h). (Refer to 22 - TIRES/WHEELS/TIRE PRESSURE MONITORING/SENSOR - OPERATION). If the TPM system detects that the tire pressure in any road tire is going low, beyond the Low Pressure (lamp) ON threshold (see placard table below), the TPM system will continuously illuminate an indicator lamp. If a system fault is detected, the indicator lamp will flash on/off for 75 seconds and then remains on solid.
If the WCM detects a warning or fault condition at ignition key "on" it will wait ten seconds +/- 10 % before sending the first request to illuminate the yellow telltale. This will assure that the display module has concluded its bulb check period. The display module will request a chime once per ignition cycle for each "warning" or "fault" condition detected. A "warning" or "fault" condition will remain enabled until the problem causing the condition is corrected and removed/reset.
The WCM shall continuously monitor for the receipt of tire pressure RF message transmissions from the wheel sensors during both the ignition key "on" and key "off" cycles. The wheel sensor ID’s and the location of each sensor (e. g. Tire 1, Tire 2 etc. ) are stored in the WCM non-volatile memory during the initial Manufacturing Plant Process, or during a service procedure, as required.
The TPM System will continue to warn the driver of low tire pressure as long as the condition exists, and will not turn off the indicator lamp until the tire pressure is at or above the Low Pressure (lamp) OFF threshold (see placard table below). The system will automatically update and the TPM warning lamp will extinguish once the updated tire pressures have been received.
The tire pressure will vary with temperature by about 1 psi (6. 9 kPa) for every 12°F (6. 5°C). This means that when the outside temperature decreases, the tire pressure will decrease. Tire pressure should always be set based on cold inflation tire pressure (placard pressure). This is defined as the tire pressure after a vehicle has not been driven for more than 3 hours - and in outside ambient temperature. The tire pressure will also increase as the vehicle is driven - this is normal and there should be no adjustment for this increased pressure. For a system fault, the system will return to normal once the WCM receives a valid transmission from that sensor location.
For further information, refer to the Owners Manual or the Appropriate Diagnostic Information.
If equipped, some vehicles will have different recommended tire pressure values between the front and rear tires. The TPMS will distinguish between the front and the rear tire sensors by using transponders located in the front wheel wells on the vehicle.
These vehicles will also have a “Light Load” reset switch which will allow the driver to change between two different recommended “Placard Pressure”, “Low-pressure Threshold” and Hysteresis Pressure Values”. These values are stored in the WCM non-volatile memory during the initial Manufacturing Plant Process, or during a service procedure, as required. To determine the pressure thresholds for a vehicle, refer to the Tire Inflation Pressure (Placard) Label or Supplemental Tire Pressure Information Label, and then apply the placard pressure to the following table. The Low Pressure OFF Threshold is defined as the Low Pressure ON Threshold plus the Hysteresis Pressure Value
Thanks that was informative. I even understood most of it. .
So now I'm smart enough to ask more questions. How can I find out if my TPMS will read an extra sensor? Since my TPMS is set to read 3 different pressures, what would I keep my spare inflated to? Would I have to inflate or deflate my spare to match the rear tires every time I haul a load, since thats the sensor thats gonna read it? This is starting to make my head hurt:-laf
