Once again I have to impose on this knowledgeable group for guidance. I can't thank you guys enough for your help!
I bought this RAM late last summer and have put about 3,000 miles on it and figure it's probably a good time to rotate the tires since I don't when it was last done, if ever. With this damn hernia and being on weight lifting restrictions I figure it's probably better to pay the local tire shop to have him lift these monsters.
They rotated them and I noticed that the display (TPMS) is now showing the wrong air pressures i the dash cluster. The fronts should have 60 PSI in them and the display is showing 81 PSI. Likewise the rear tires should have 80 PSI in them and the display is showing 60 PSI. I checked the tires with the trusty Milton gage and the tires have the correct pressure in them for their actual location. The problem is the sensors are showing in the wrong location.
I have the ALFA OBD APP and the MX2 scan module and looked all through the body computer settings and couldn't find an option to reset them. Is it possible to reset them with ALFA OBD? If not, how can I reset them, or is this something I need to live with until the next tire rotation, or buy another tool?
Appreciate any and all help!
Thank you again!
Mark
Thank you again!
Mark
