Tps Cleaning
Thanks again Howard for all your help. I thought it might help some of the other members like me, who are a little nervous about working on the TPS, to hear my experience. Reading the various posts on this issue, I sprayed the TPS while still mounted in the truck. It worked for a day or two at a time. You need to take it off the truck to clean it properly.
Unhook the electrical connector. Remove the two screws with a 7mm socket and the TPS falls off in your hand. I shot a puddle of electrical contact cleaner in the opening at the back of the TPS and moved the actuator with the screwdriver blade on my pocketknife. I heard a grinding sound. The actuator and spring evidently had enough grit in them to cause interference with the action of the TPS. I sprayed the area a few more times and cleaned it out with Q-tips. I then cleaned the pin that the TPS mounts on. Remounting was easy too. Tilt the electrical connector end of the TPS down and it slips right on to the mounting pin. The truck ran great again. I had the thing replaced a couple of years ago by a Dodge dealer. It cost over $200 for parts and labor.
If it ever has to be replaced, it is something that any owner could do in minutes. Its easier than an oil change.
A minor mod, that may stop the problem, will be to fashion a boot over the back of the TPS, to keep the grit out.
I wouldn’t imagine that the TPS wears out internally in a couple of years. Hearing all that grit makes me believe that the problem comes from outside.
It has only been a few days since I cleaned the TPS. The truck is still functioning normally. I will uncross my fingers tomorrow.
I am going to add the potentiometer that Howard has developed and add some test posts as he suggested to me.
Hope this helps.
Joe
94 2500 4x2, Auto. Banks Power Pac, Banks Brake, Twin Ram Intake. Feels like as much power as my 05 2500 4x4 QC short box 6spd.
