TPS Delete Kit
getrag 360 vibration
speedometer repairs, a new problem
I've got a freind that I helped install one on his 91.5 that has worked quite well until a dump truck pulled out in front of him. It took a little trial and error to get the to shift when he wanted to but he was happy with the way it worked. Not sure where he got it but the kit had every thing he neded including good instructions on instalation and getting the shift pionts right. He found a '93 about a year ago and will install it on that truck later this year.
I checked with my freind and it was a DNR kit.
Bob
i put one on a 95 and he loves it. i think for my use a new apps would be better, but the dnr kit works as advertized and it isn't permanent. if you ever decide to hook an apps back up, it's quick and easy.
Yes, I installed mine 6 months ago. Absolutely love it! Flawless performance once I set it at my desired shift point. I would highly recommend replacing OEM TPS with this as you know the OEM one will eventually fail on you. Am getting another one for my Cummins R/C swap.
Ran one on a 97 and it worked great. A little trial and error to get shift point where you want it and then forget it. Ran it about 3yrs till truck was retired.
