After doing lots of reading here I am still confused.
Truck - 97 3500 4x4 47re <rebuilt, billet single disc TC>. Linkage set per specs.
Running empty it shifts through all the gears / OD / lock up - sort of.
OD off - Any more that 60% throttle the TC unlocks
OD on - will shift into OD, and lock up if you are less the 50% throttle. TC will stay locked / OD on unless speed drops off.
When towing it still functions, but have this issue:
OD off - will only lock up at less than 50% throttle, and more then 60% throttle the TC will unlock. Makes towing difficult.
Basically any more then 50 to 60% throttle will cause the transmission to unlock and shift out of OD.
Towing is done in area of heavy traffic (So Cal) and the mountain / desert roads. Want to be able to tow with OD off and TC locked up to 80% throttle (desert / mountain roads), and then OD off / TC unlocked (So Cal traffic).
From what I have read the TPS control the OD function. But does it also control the TC fundtion when OD is off?
Will adjusting (elongating mounting holes) the TPS achive what I want to do?
Or will I need to do the 3 position switch and the in-cab potentiometer conversions?
